I can’t edit the code in my c# script component. Code is in there, the component works, but I can’t edit it. When going to code editor, no code is visible, see the attached picture bellow.
Can you run systeminfo in rhino to see what specific version is running?
Rhino 8 SR8 2024-5-14 (Rhino 8, 8.8.24135.14001, Git hash:master @ 8c191427bc5c6c4e62f523a752d809f68897c3a5)
License type: Commercial, build 2024-05-14
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.18
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 11-7-2023 (M-D-Y).
- Secondary monitor is laptop's integrated screen or built-in port
- Windows Main Display attached to adapter port #2
Primary OpenGL: NVIDIA RTX 2000 Ada Generation Laptop GPU (NVidia) Memory: 8GB, Driver date: 1-22-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.27
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-22-2024
Driver Version: 31.0.15.3827
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Users\cameron.behning\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Crash\1.4.2-beta\Crash.rhp "Crash" 1.4.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.8.24135.14001
C:\Users\cameron.behning\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2021.3.2.446\PanelingTools.rhp "PanelingTools"
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp "Grasshopper" 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
As a note, I experienced this both with R8.7 yesterday morning, then also with R8.8 after an auto update. Additionally, it seems I can still select code, delete it, edit it, etc, I just simply can’t see what is happening.
A couple things:
- The Intel(R) Iris(R) Xe Graphics (Intel) driver is a bit old. I would get it updated. https://www.intel.com/content/www/us/en/support/detect.html . Make sure to restart everything after install.
- If there is a new blank Grasshopper canvas. Drop a new C# script component there. Will that show the text? Will it accept typing?
intel claims the driver is up to date. Regardless, the Script component just started working as normal with no clear indication as to what changed. Chalk this down to something funny and weird, but hopefully exceedingly rare.
