Hello
First thanks to you for this wonderful tool, “Rhino inside Revit.”
Second, when trying to place the script component in the grasshopper (Rhino 8). the below message keep popping. and when closing it, I appear with a message (1. Error building code | Method not found: ‘System.ReadOnlySpan1<!0> System.Collections.Immutable.ImmutableArray1.AsSpan()’.)
and can’t open it
I will appreciate any help.
Hi Mohamed,
We’ll need more information to be able to help.
Can you post your script? Is the scripteditor working for you in Rhino (not inside Revit)?
Thanks
Hello Japhy
It is just an empty grasshopper script.
yes it is working with Rhino (not inside Revit)
Thnaks
To troubleshoot lets remove 3rd party Revit plugins.
This tool makes that easy to test. Rhino.Inside®.Revit
Got it, thanks for reporting.
For reference
RH-80065 SciptEditor C# exception on placement
