Is that normal ? I just renamed the layes, the rest is all the same
Hello- it’s hard to say but if the file was initially saved as ‘SaveSmall’ then a normal save, depending on the contents of the file, might be quite a lot larger. Can you try SaveSmall and see of that seems more correct?
