Hello
I try to save hatch using makeHatch plugin without display the dialog box, is that possible?
file = r"C:....../test.pat"
command = "makeHatch X 1 Y 1 D 0.1 Enter test test "
rs.Command(command,True)
Hello
You should be able to run each command in scripted mode by prepending a - (dash) to the command name.
Thanks @menno
Save as always show the dialog, i want save the file directly
Thank you @menno , this is a vey helpful information.
The problem here is that makeHatch give only this line to save the file:
Save hatch as ( Browse ):
is this the plugin by @SamPage ?
Hi @Gijs
Yes
