Runtime error using _changelayer
This has nothing to do with running python scripts, it is a Java script error caused by the command help - which you have running on the right hand side in the vertical bar.
To fix this you should update your installation to the latest service release and also see this Wiki page as well as this discussion:
HTH, --Mitch
