Run Python script on startup
Hi all,
How can I run a python script on startup from the command line. I tried this:
rhino.exe  /runscript="_RunPythonScript D:/test.py"
or
rhino.exe /runscript="D:/test.py"
but neither work…
Cheers
Patrick
I think I found it.
rhino.exe  /runscript="_-RunPythonScript D:/test.py"
Also, this skips splash screen and the question about units:
rhino.exe /nosplash /notemplate  /runscript="_-RunPythonScript D:/test.py"
Patrick
I can’t get something similar working with Rhino5
Paste this in the command line and the python the script runs fine
_-RunPythonScript C:/Users/IEUser/Desktop/rhino/DrawParametricCurve.py
with this command from a bash shell
"C:/Program Files/Rhinoceros 5 (64-bit)/System/Rhino.exe" /nosplash /runscript="_-RunPythonScript C:/Users/IEUser/Desktop/rhino/DrawParametricCurve.py", "./base.3dm"
rhino start, opens ./base.3dm but the python script isn’t run.
must be an escape issue or syntaxery magic thing…
"C:/Program Files/Rhinoceros 5 (64-bit)/System/Rhino.exe" /nosplash /notemplate /runscript='_-Exit'
It seems the runscript argument is not evaluated.
I should add that i’m using an evaluation version.
edit: I found out that the above command does work in the ‘command prompt’ of windows, but NOT in the ‘cygwin bash shell’, nor in the ‘PowerShell’. I think this is an important piece of the puzzle. unfortunatly I don’t understand either shells enough to see why the runscript argument wouldn’t be passed (notemplete or nosplash work fine…)
Hope someone knows what this can be
Thanks
