I am developing a plugin that needs to run automatically whenever Rhino starts. Is there a way to do so?
Thanks,
Best
Yifan
Thanks,
Best
Yifan
Override the LoadTime property on the plug-in class and return AtStartUp
Thanks Steve,
I tried it out but does not work as I expected. Overriding loadTime property allows to load the plugin at startup, does that mean the plugin will run automatically, or just loaded and ready to be run?
Yifan
The plug-in will be loaded automatically when Rhino starts. What version of Rhino are you using.?Older versions did not change the load time setting stored in the registry.
I am using Rhino 5 and RhinoCommon. I launched Rhino 5 through Visual Studio debug.
To further clarify, I would like to, at the startup of Rhino, load the plugin, and run a command of the plugin. I may have loaded the plugin at startup, but how do I run my command as soon as the plugin is loaded?
I copied my plugin class here, hoping I am not doing anything wrong.
Thanks!
Yifan
public class Plugin : Rhino.PlugIns.PlugIn
public IrisReaderPlugin()
Instance = this;
///<summary>Gets the only instance of the IrisReaderPlugin plug-in.</summary>
public static IrisReaderPlugin Instance
get;
private set;
public override PlugInLoadTime LoadTime
get { return PlugInLoadTime.AtStartup;}
You cannot run a command while the plug-in is loading. Instead, you have to wait until Rhino has fully initialized, and then run the command. This is done by subscribing to the RhinoApp.Idle
event, and then when it fires, to run the command like so:
public class IrisReaderPlugin: Rhino.PlugIns.PlugIn
Instance = this;
RhinoApp.Idle += OnIdle; //subscribe
private void OnIdle(object sender, EventArgs e)
RhinoApp.Idle -= OnIdle; // unsubscribe
RhinoApp.RunScript("_MyCommand Option1=Value1 Option2=Value2", false);
get;
private set;
I haven’t tested this, but it should work
Menno,
Yes, that is exactly what I’d like to do.
Your code works like a charm!
Thank you so much!
To execute a Rhino command? No.
– Dale
