Hi Dale,
I just tried the new method - thank you for adding it!
I see two issues with how it is now implemented:
- I don’t see a way to disable clipping in one vport only, but keep clipping in others.
- How can I tell if the clipping plane is enabled or disabled in the given vport?
(also, it is not easy to add one view to the ‘clipped’ ones… if I use only one view, it would ‘unclip’ the others, so every time I’d need to keep a list of views that need to remain clipped…and with not being able to tell what’s clipping via script it makes is difficult.
In my initial suggestion, the method would take the ClippingPlaneID, strViewName/ID, True/False for enabled/disabled and return True/False for enabled/disabled. It would solve the above 2 issues. What do you think ?
–jarek
