Hi All,
I really need some help from someone in McNeel if possible as I think the problem is a bug in the add fillet curve command, maybe not and someone can tell me otherwise. I will be quite happy to find out either way.
This script is run from within another script and all variables are working it does everything except insert that last fillet curve.
The problem is the rs.AddFilletCurve for curves 4 and 5, the curves appear to be made correct yet the rs.AddFilletCurve fails to add a new curve to the document. As you will see I have used this command at the start of my script and in that context it works fine, I have also been able to manually add a fillet to curves 4 and 5 along with the radius as in the script.
It just doesn’t want to play ball in the script, so please put me out of my misery I am always wanting to learn and this has been a day wasted for something I just cannot see.
Roger
#! python 3
#import rhinoscriptsyntax as rs
#import scriptcontext as sc
import math
import Rhino.UI
#import System
#import System.Collections.Generic
#import Rhino
#import Eto.Drawing as drawing
#from Eto.Drawing import Padding
#from Eto.Forms import Dialog, DropDown, DynamicLayout
#import Eto.Forms as forms
# Imports
import Rhino
from Rhino.UI import RhinoEtoApp
from System.Collections.ObjectModel import ObservableCollection
import configparser as cp
import System
import os
from pathlib import Path
# New Rerun/Exit Dialog Class
class RerunExitDialog(forms.Dialog[bool]):
def __init__(self):
super().__init__()
self.Title = "Rerun or Exit"
self.Padding = drawing.Padding(10)
self.Resizable = False
# Create label
self.m_label = forms.Label()
self.m_label.Text = "Do you want to rerun the script or exit?" # Fixed: Added Text argument
# Create buttons
self.m_rerun_button = forms.Button()
self.m_rerun_button.Text = "Rerun"
self.m_exit_button = forms.Button()
self.m_exit_button.Text = "Exit"
# Set button actions
self.m_rerun_button.Click += lambda sender, e: self.Close(True)
self.m_exit_button.Click += lambda sender, e: self.Close(False)
# Create layout
layout = forms.DynamicLayout()
layout.Spacing = drawing.Size(5, 5)
layout.AddRow(self.m_label)
layout.AddRow(self.m_rerun_button, self.m_exit_button)
# Set the dialog content
self.Content = layout
# Secondary script
def ASME_B_16_5_45_Long_Radius_Elbows():
try:
print("Config values in secondary script:",config_values)
rad = float(config_values.get('dim 4'))
print("Radius1:", rad)
curve1 = rs.GetObject("Select 1st curve to fit", rs.filter.curve, True)
curve2 = rs.GetObject("Select 2nd curve to fit", rs.filter.curve, True)
if not curve1 or not curve2:
print("Object selection canceled.")
return
# CurveFilletPoints(curve_id_0, curve_id_1, radius, base_point_0, base_point_1, return_points)
fillet = rs.CurveFilletPoints(curve1, curve2, rad)
if fillet:
rs.AddPoint(fillet[0])
rs.ObjectName( rs.FirstObject(), 'NIP 1' )
rs.AddPoint(fillet[1])
rs.ObjectName( rs.FirstObject(), 'NIP 2' )
rs.AddPoint(fillet[2])
rs.ObjectName( rs.FirstObject(), 'NIP 3' )
curve3 = rs.AddFilletCurve(curve1, curve2, rad)
#point = rs.LineLineIntersection(curve1, curve2)
#if point:
#rs.AddPoint(point[0])
#rs.AddPoint(point[1])
param1 = rs.CurveClosestPoint(curve1, fillet[0])
print("Curve parameter1: {}".format(param1))
rs.SplitCurve(curve1, param1)
param2 = rs.CurveClosestPoint(curve2, fillet[1])
print("Curve parameter2: {}".format(param2))
rs.SplitCurve(curve2, param2)
if curve3:
OIP = (0,0,0)
#OIP = rs.AddPoint(0,0,0)
#rs.coerce3dpoint(OIP)
print(OIP)
OIP1 = (0,float(config_values.get('dim 1')),0)
rs.AddPoint(OIP1)
rs.ObjectName( rs.FirstObject(), 'OIP 1' )
print(OIP1)
OIP2 = (float(config_values.get('dim 2')), float(config_values.get('dim 3')),0)
rs.AddPoint(OIP2)
rs.ObjectName( rs.FirstObject(), 'OIP 2' )
print(OIP2)
OIP3 = (float(config_values.get('dim 4')),float(config_values.get('dim 1')),0)
rs.AddPoint(OIP3)
rs.ObjectName( rs.FirstObject(), 'OIP 3' )
print(OIP3)
curve4 = rs.AddLine(OIP, OIP1)
print(curve4)
curve5 = rs.AddLine(OIP, OIP2)
print(curve5)
if curve4 and curve5:
print("Lines created successfully. Attempting to create fillet.")
rs.AddFilletCurve(curve4, curve5, rad)
#internal = rs.AddPipe(curve, 0, float(config_values.get('dim 3')) / 2)
#offset = (float(config_values.get('dim 2')) - float(config_values.get('dim 3'))) / 2
#rs.OffsetSurface(internal, offset, tolerance=None, both_sides=False, create_solid=True)
#rs.DeleteObject(internal)
print("End of 45 Long Radius Elbows")
except Exception as e:
print(f"Error in 45 Long Radius Elbows: {e}")
# Main script logic
#if __name__ == "__main__":
def RunScript():
while True:
# Run the Pulled Bends function
# Ask the user if they want to rerun the script or exit
rerun_dialog = RerunExitDialog()
rerun_result = rerun_dialog.ShowModal(Rhino.UI.RhinoEtoApp.MainWindow)
if not rerun_result:
print("Exiting script.")
break
# Execute the rerun logic
RunScript()
