Hello, I am trying to select different surfaces and then try to rotate them along an axis, but I can’t achieve it because in order to rotate, I need to assign a different object name to each object. The number of surfaces selected can vary. I am using Rhino 5 and visual Studio 2010.
CRhinoGetObject go;
go.SetCommandPrompt( L"Select surfaces" );
go.SetGeometryFilter( CRhinoGetObject::surface_object );
go.GetObjects( 1, 0 );
if( go.CommandResult() != success )
return go.CommandResult();
// Validate selection
const CRhinoObjRef& obj_ref = go.Object(2);
const CRhinoObject* obj = obj_ref.Object();
if ( go.Result() == CRhinoGet::object )
int i, object_count = go.ObjectCount();
for ( i = 0; i < object_count; i++ )
const CRhinoObjRef& obj_ref = go.Object(0);
ON_wString prompt("");
prompt.Format( L"Number of selected surfaces: %d \n", go.ObjectCount());
RhinoApp().Print( prompt );
CRhinoGetObject go1;
go1.SetCommandPrompt( L"Select border" );
go1.SetGeometryFilter( CRhinoGetObject::curve_object );
go1.GetObjects( 1, 1 );
if( go1.CommandResult() != success )
return go1.CommandResult();
const CRhinoObjRef& refBord = go1.Object(0);
const CRhinoObject* obj_bord = refBord.Object();
const ON_Curve* border = refBord.Curve();
if( !border )
return failure;
ON_3dVector axis_normal(1, 0, 0);
ON_3dPoint lowP(0, 0, 0);
ON_Xform xform;
xform.Rotation(-1*0.53,axis_normal,lowP);
//we rotate the angle
const CRhinoObjRef refSurf_new = context.m_doc.TransformObject(obj, xform, true, true, true);
const ON_Surface* srf_new = refSurf_new.Surface();
const CRhinoObjRef refbord_new = context.m_doc.TransformObject(obj_bord, xform, true, true, true);
const ON_Curve* border_new = refbord_new.Curve();
context.m_doc.Redraw();
return CRhinoCommand::success;
