I have an arbitrarily rotated section plane, is it possible of my orthographic views (top, front, left) to align section plane temporally?
If I understand your questions correctly, you can first turn on âUniversal constructions planesâ in Options > Modeling Aids. This will keep the CPlanes in the viewports oriented 90Âș to each other.
Then use the Cplane command with the 3Point option to pick three points to orient your CPlane to your section plane.
Does that help?
Yes definitely! Thank you for your help
