Rotate plate around a pipe axis
Hi there,
Does anyone know how to rotate these plates along a line? Here I am using a centre point to rotate which partially does what I want but at some points the pipe goes through the plate at the centre point. I have tried to use the plane to rotate as well but all it does is rotate the plates side by side which is not what I want.
(the second photo is what’s I want)
I am also trying to connect the pipe vertically without discontinuities. I have tried doing this with endpoints but have trouble understanding how to shift the list so it connects with the one above and below.
If anyone knows how to solve this that would be great!
Rotate on Axis.gh (39.2 KB)
Thank you,
Jessie
Use the Rotate Axis component.
