is there a way to use axis to mirror, not a plane ?
thnx!
you can rotate around an axis, using “rotate axis” component, just rotate 180 degrees, or pi radians, around, for exam, the x axis
that works ! thnx mark
that’s pretty neat! I’m trying to grow a pattern along borders &
thought ‘mirror along axis’ sorta node might make keep the def short ; ]
thnx @HS_Kim !!
Depending on what you are doing with the surface, M Kim’s approach maybe is better; with rotation, this will also rotate the normals of the surface, curve start point, etc, which can cause issues later. I simply did not think of the mirror curve component when I suggested rotate
yep, im actually sorting thru those ‘issues’ rgt now ;] thnx mark!
