Rotate object around bounding box centroid using rhinoscript
I’m trying to rotate an object around it’s own center. So I have found the centroid of its bounding box, but I’m stumped as to how I should use the coordinate information of this centroid to define the rotation center:
baseObjects = flattenList(baseObjects)
cageObjects = rs.SelectObjects(baseObjects)
rs.Command("_BoundingBox _Enter")
rs.UnselectAllObjects()
Box = rs.LastCreatedObjects()
centroid = rs.SurfaceAreaCentroid(Box)
rs.RotateObjects(cageObjects, centroid, 45)
Obviously this rotation won’t work, I tried. But what way do I pass the coordinate info of the centroid on to the rotation command?
Hi @SNC,
How about this?
import Rhino
object_ids = rs.NormalObjects()
for id in object_ids:
    bbox = rs.BoundingBox(id)
    center = rs.PointDivide(rs.PointAdd(bbox[4], bbox[0]), 2.0)
    rs.RotateObject(id, center, 45.0, Rhino.Geometry.Vector3d.ZAxis)
– Dale
Thanks, that will work!
For info this is rhinoscriptsyntax in Python, which is different from the VBScript-based RhinoScript. You can label questions with Python and have more chances of getting an answer from someone who knows Python.
-g
Thanks for the tip, I’ll keep it in mind.
