Hi there, struggling to get this to work.
I have some set surfaces, that are curved, and I wand to rotate them all vary degrees perpendicular to themselves.
I’ve had a go and attached what I have with some manual tests.
The plan would be for me to select the bottom row - rotate them all perpendicular to themselves say 90 degrees, then select the next row and rotate a differing amount.
Any help? Thanks in advance!
Yep - appreciate your feedback thank you. Learning as I go here…I do need to take some tutorials on this but kinda been thrown in at the deep-end! So learning as I go…will try and be as specific and clear as I can be in future. Thanks again!
