RIR editing loop
Hi, masters. I’m encountering an issue with Rhino Inside Revit.
This is the workflow I planned based on a GH template:
Workflow:
  1. Extract objects from families in Revit.
  2. Then, bake them into Rhino/GH, make edits, and create new family objects (which can be edited in Revit), to be added and displayed in the Revit 3D view.
Currently, in my Revit project, I can see the newly created family in the list, but how can I make the object display physically in the 3D view of Revit?
The ultimate goal of this workflow is to use Rhino Inside Revit to read the entire Revit project model, adjust or add objects in Rhino/GH, and finally reintegrate them back into the Revit project for collaboration with Revit users who do not have Rhino Inside Revit installed.
Reference:
Converting Revit Geometry to Rhino
Create Revit Family with Rhino in Revit (by Tianhui Zhang)
Test files:
Env: Revit 2025 / Rhino 8
d291124_Qs_rac_basic_sample_project.rvt (19.0 MB)
d291124 Qs Rvt object loop Sample_Revit_to_Rhino_v1.gh (117.4 KB)
Hi! Masters, are there any parameters or components that I haven’t noticed?
Or is it merely like grsaahopper to Rhino, where there’s a component that can bake and push the content to the viewport? :melting_face:
You content is pushing, but its rather small and on a Phase that is not visible in that view.
Thank you, Japhy!
So I should reimport this Revit family by the RIR and then modify the Phase status in Revit?
Let me give it a try.
You can change how the view displays the status or switch to a view that is showing the object to edit.
