RhinoPython rs.IsPolyline raises an exception
I think rs.IsPolyline does not work the way it should. The following code chunk will stop with an error if you select a point or anything but a polyline. I’d expect that it should finish gracefully with res=False.
guid = rs.GetObject("select point")
res = rs.IsPolyline(guid)
If you agree the fix would be simple: In curve.py, line 3165 the last argument should be converted from True to False and then read:
curve = rhutil.coercecurve(object_id, segment_index, False)
I’m running Rhino for Windows Version 6 SR17 (6.17.19235.15041, 23/08/2019)
Best regards,
Gero.
Yeah, how the different Is...() functions are written a bit of a mish-mash, most have True arguments in rs.coerce... which force an exception to be raised if the object type isn’t correct - but a few don’t…
Those that don’t (as far as I can tell from the code):
IsCurve()
IsCurveClosed()
IsBrep()
IsPolysurface()
IsSurface()
Probably a few more…
I agree. I added a bug report.
Thanks for reporting.
