Rhinopython error
I want to make an algorithm using rhinopython that works the same as range&domain, but it has an error.
How can I handle this problem?
domain&range.gh (6.7 KB)
The error is in line 6 of your code:
Make this change to line 6 and your code works:
-Kevin
Thanks!
Can you let me know why you change โ€œif i <= len(Y)โ€ to โ€œif i < len(Y)โ€?
I can see it works well but still donโ€™t get why itโ€™s solved.
This is from your original code:
In your gh definition:
  • You have 10 items at input X
  • You have 3 items at input Y
    • Y[0], Y[1], and Y[2]
  • When the loop in line 5 gets to the point where i = 3
    • Line 7 tries to access Y[3] generating the error: Solution exception:index out of range: 3
-Kevin
