RhinoCommon Intersection.MeshPlane() method Slower in Rhino8
Hello, I am a Rhino Plugin developer.
We are currently upgrading the plugin to Rhino8 version.
The MeshPlane method takes too long to execute.
I’ve also tested the method for inserting a MeshIntersectionCache (see below), but it’s still slow.
Is there any way to improve this part?
Hi @tr1004sm,
Can you provide a model, along with sample source code that we can run here, that exhibits this slowness?
Thanks,
– Dale
There is nothing special about the code
To check the API speed, the code was tested by putting it in a loop.
And The file I tested was 3D scan data and had a large number of mesh vertices.
Please understand that we cannot provide samples directly as they are production-applied products. Rhino Object information is provided as follows. (It is expected that the greater the number of mesh vertices, the greater the difference compared to lower versions of Rhino.)
What if you put the creation of the cache outside of your loop. From the little code I can see it looks like you are creating a new cache for every time you perform an intersection.
As a result of the test, the speed is similar even if the cache creation is done outside the loop. I also tested the tolerance from 0.1 to 0.0001 and the speed is similar.
Also, is there any way to convert the mesh state to perform intersection? As shown below, the execution speed of the first method of the RhinoCommon method and the execution speed of input 10 planes in the second method are the same.
In my case, the suggestion of Giulio did solve the speed problem. Maybe you should use 1.0e-10 as value for the tolerance ? But it seems to work only if the section plane is parallel to the XY plane.
I could solve that by first transforming the mesh to be aligned with the section plane (planeToPlane transform), and then transforming the resulting polylines back to the original coordinate system. Then I get a similar speed to V7.
testIntersectMeshToPlane.gh (821.5 KB)
I also found this problem and it affects the speed of my tool. @Gijs
@taraskydon not sure if I understand your issue correctly, but in your script you are not assigning the result of the mesh plane intersection to output A
This does not affect the processing speed.
I use this method to draw a line of demarcation.
https://youtu.be/vpujH8xOwF4 Here is a visual representation of the processing speed. !
ah, Totally missed the issue, sorry. I’m not seeing that dramatic of a difference between Rhino 7 and Rhino 8, but it is certainly slower (here about a factor 3) 40ms vs 115ms in Rhino 8.
I think @piac will be the better person to ask why this is slower in Rhino 8 and if something can be done about it.
if you test in GH, then reconnect the mesh to the nodes to see the difference. i have it in x34 Slower :sweat_smile:
@taraskydon - I see you are not passing a cache object as a parameter.
– Dale
If I hang the cache separately and reconnect the grid, the processing speed increases, but the problem is that because of this separate process, I will have to create a separate plugin for version 8, which I don’t really want to do :pensive_face:. maybe I can use it. System.Reflection to compile a native method.
