RhinoCommon in pythonscript
I wanted to write a ‘‘saved selection’’ function for Rhino 6 from ‘‘named position’’. I tried to get access to the plugin ‘‘Named Position’’, so I used RhinoCommon to inquiry the GUID and then use ‘‘Find’’ to get a plugin object. However, I found the GUID, but I cannot locate the plugin object. I don’t think it’s a correct
output.
Hi @charlottewyy,
Try using the NamedPositionTable object. You can get it from the document
import Rhino
import scriptcontext as sc
named_positions = sc.doc.NamedPositions
for id in named_positions.Ids:
    print(id)
– Dale
