Hi, I am new to Rhino SDK.
I am trying to create a mesh through the example code from the SDK document, but I got some issues at the very beginning.
below is my code:
Mesh mesh = new Mesh(); //<- I got an error from here!
mesh.Vertices.Add(0.0, 0.0, 1.0); //0
mesh.Vertices.Add(1.0, 0.0, 1.0); //1
mesh.Vertices.Add(2.0, 0.0, 1.0); //2
mesh.Vertices.Add(3.0, 0.0, 0.0); //3
mesh.Vertices.Add(0.0, 1.0, 1.0); //4
mesh.Vertices.Add(1.0, 1.0, 2.0); //5
mesh.Vertices.Add(2.0, 1.0, 1.0); //6
mesh.Vertices.Add(3.0, 1.0, 0.0); //7
mesh.Vertices.Add(0.0, 2.0, 1.0); //8
mesh.Vertices.Add(1.0, 2.0, 1.0); //9
mesh.Vertices.Add(2.0, 2.0, 1.0); //10
mesh.Vertices.Add(3.0, 2.0, 1.0); //11
mesh.Faces.AddFace(0, 1, 5, 4);
mesh.Faces.AddFace(1, 2, 6, 5);
mesh.Faces.AddFace(2, 3, 7, 6);
mesh.Faces.AddFace(4, 5, 9, 8);
mesh.Faces.AddFace(5, 6, 10, 9);
mesh.Faces.AddFace(6, 7, 11, 10);
mesh.Normals.ComputeNormals();
mesh.Compact();
the error message is “An unhandled exception of type ‘System.DllNotFoundException’ occurred in RhinoCommon.dll.
Unable to load DLL ‘rhcommon_c’: The specified module could not be found. (Exception from HRESULT: 0x80070007E)”
How can I solve the issue?
