[RhinoCommon] CustomMeshObject - how to use RecordHistory?
(Menno Deij - van Rijswijk) #1
We use a CustomMeshObject in our plug-ins. I have tried to add instances of this class with a HistoryRecord to the RhinoDoc, but have not succeeded in finding out how to do this.
Typically, we add the custom object like this:
Mesh m; // defined elsewhere
MyCustomMeshObject o = new MyCustomMeshObject(m);
doc.Objects.AddRhinoObject(o);
Guid g = o.Id;
But: RhinoDoc.AddRhinoObject has no signature that also supports adding a HistoryRecord.
I’ve tried the approach below, but replacing the mesh with the custom mesh object breaks the history immediately.
HistoryRecord h = new HistoryRecord(this, 1);
WriteHistory(h);
Guid g = doc.Objects.AddMesh(m, null, h, false);
RhinoObject obj = doc.Objects.Find(g);
MyCustomMeshObject o = new MyCustomMeshObject(obj.Geometry as Mesh);
doc.Objects.Replace(new ObjRef(obj), o); // this breaks the history defined above
@dale or @stevebaer, do you have any hints on how to support history with custom objects?
(Dale Fugier) #2
I am not seeing a way to add a HistoryRecord to a custom object. Clearly there should be an override to doc.AddRhinoObject where you could pass a HistoryRecord object.
I’ve addded this feature to the RhinoCommon wish list. If we ever make the list public, you can see your item here.
http://mcneel.myjetbrains.com/youtrack/issue/RH-22907
(Menno Deij - van Rijswijk) #3
Ok. I am not familiar with the C++ SDK, but can this be achieved in that environment?
(Dale Fugier) #4
Yes it can.
(Menno Deij - van Rijswijk) #5
If this is going to be implemented in RhinoCommon, functionality for CustomObjects should also be added to ReplayHistory. Specifically to
replayData.Result[0].UpdateTo[...]
Currently, only standard geometry is allowed in the Update statements. So, even though I succeeded in setting a history record on my custom object by some excursion to C++ from C#, replay history is only capable to update as a mesh, not a custom mesh.
It would be nice to have this functionality in an upcoming SR, if possible.
(Brian Gillespie) #6
RH-22907 is fixed in the latest Rhino 6 Service Release Candidate
#7
I’m having problems using the method recently implemented: [RhinoCommon] AddRhinoObject HistoryRecord
Regards,
(Brian Gillespie) #8
RH-43591 is fixed in the latest Service Release Candidate
