I have started working with the static Brep method, CreateDevelopableLoft. In general I have been getting good results but for some reason these particular curves are failing to generate a Brep even though the DevLoft command does so perfectly fine. I’ll attach the sample file containing the two rails and the sample command.
DevLoftSample.3dm (38.1 KB)
DevLoftSampleCommand.cs (1.6 KB)
That’s because of a bug here. It’ll be fixed soon
https://mcneel.myjetbrains.com/youtrack/issue/RH-49730
Hi Lowell,
I don’t see issue 49730, but I’ll take your word for it that you’re working on it. Many thanks and have a great weekend!
Larry
