Is there a similar function to this one but instead of using breps I am looking for planes:
http://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Brep_Split.htm
1.) Define your Plane.
2.) Using your plane, create a PlaneSurface.
3.) Using the surface, create a Brep using Surface.ToBrep.
– Dale
Dear Dale,
Thank you.
All steps you described works for me.
I have an issue with rhinocommon checking IsPointInside.
Why the point that is visibly inside one brep, returns true for both breps?
Screenshot and file attached
I had to do explode stuff:
Duplicate all brep faces and join them to new brep.
Still would like to know why this ispointinside did not work
Brep[] splitBrep = SolidCopy.Split(cutters[i], Rhino.RhinoDoc.ActiveDoc.ModelAbsoluteTolerance);
for(int j = 0; j < splitBrep.Length;j++){
splitBrep[j] = splitBrep[j].CapPlanarHoles(Rhino.RhinoDoc.ActiveDoc.ModelAbsoluteTolerance);
Brep[] explodedBrep = new Brep[splitBrep[j].Faces.Count];
for(int k = 0; k < splitBrep[j].Faces.Count;k++){
explodedBrep[k] = splitBrep[j].Faces[k].DuplicateFace(false);
splitBrep[j] = Brep.JoinBreps(explodedBrep, Rhino.RhinoDoc.ActiveDoc.ModelAbsoluteTolerance)[0];
I don’t know how relevant this is for your work, but you may want to look at the clipping volume work I did: https://github.com/mcneel/RhinoCycles/blob/rhino-6.x/conversion/clipping_volume.gh
It should contain a C# script component that also splits breps with a plane.
Modify your code to look something like this:
splitBrep[j].Faces.SplitKinkyFaces(RhinoMath.DefaultAngleTolerance, true);
if (BrepSolidOrientation.Inward == splitBrep[j].SolidOrientation)
splitBrep[j].Flip();
– Dale
