Cut object by plane
I have an ObjRef from GetObject.
Now I want to split this object in 3 parts by dividing with to planes . Is there a way to do this?
Basically I would like to have a version of https://developer.rhino3d.com/5/api/RhinoCommonWin/html/M_Rhino_Geometry_Brep_CreateContourCurves.htm where I just get an array of objects back, divided along the conture lines.
EDIT:
Ok, I tried some things.
The most promising lead was this post by Dale RhinoCommon Brep split by plane
I did like it was written there, I get a PlanarSurface, when I draw it, it is straight throug my object etc. But Brep.Split simply continues returning 0 objects. This is slowly a bit unnerving.
Effectively, I just need the functionality of the BooleanSplit Comman in the Interface. I also tried RunScrip to use the BooleanSplit directly, but it also just returnes with false…
In pseudocode, I would do something like this:
List<ObjRef> SplitByPlanes(ObjRef obj, List<Plane> cutters) {
--var splitObjs = new List<obj> {obj};
--foreach (Plane cutter in cutters) {
----var objCache = new List<obj>();
----foreach (ObjRef obj in splitObjs) {
------objCache.Add(SplitByPlane(obj, cutter));
----splitObjs = objCache;
--return splitObjs;
List<ObjRef> SplitByPlane(ObjRef obj, Plane cutter) {
--return obj.Split(obj, cutter);
Hi Chuck,
thank you for your answer.
The generall setup is clear to me - what I need is the function to perform the actuall splitting, in your code the
As far as I can see, the ObjRef Class does not offer a function “Split” (RhinoCommon API)
I can only find a split method for Breps (RhinoCommon API), but this also requires an Brep as cutter, and planes cannot be converted to Breps.
I think I could somehow piece together a way to represent my plane as Brep, but it seems like an unnecessary detour to me. Thus I was wondering if there is a more direct way.
My bad, obj.Split was a bit of a hand-wave because I wasn’t sure either, misunderstood.
Do you have a copy of the brep and plane returning nothing that you can upload? Dale’s example looks like it should work pretty reliably.
Also, a few alternatives to test (that are actually real, but maybe not as efficient):
brep.Trim(plane, tolerance) result is one contour
plane.Flip()
brep.Trim(plane, tolerance) result is next brep to trim
or
Geometry.Intersect.Intersection.BrepPlane(brep, plane, tolerance, out crv, out pt)
var splitter = Brep.CreatePlanarBrep(crv)
Brep.Split(splitter)
Ok, I am now just converting everything to a Mesh (object and splitting plane) and can then do Mesh.CreateBooleanSplit
This works, but having to convert everything is somewhat cumbersome. There really should be a Split(Obj, Plane) Method…
