RhinoCommon API documentation - wishes / critique
Hi @mkarimi,
this user question is a good example of how confusing the new help doc can be for users which never worked with the old docs:
The AngularDimension in the new docs lists multiple constructors which do not exist, eg. the one with 5 inputs is only there since Rhino 8. I do not see the methods which where located under Create in the old docs:
grafik
I would like to repeat my wish to list all constructors with seperate tree nodes (preferably including their arguments) as it has been in the old docs. The current system requires too much scrolling to find the required constructor or to note that there are multiple constructors available to choose from.
One thing which i find more annoying than useful is that i cannot open multiple sub nodes at the same time eg. Constructors, Properties and Methods. It seems to collapse expanded tree nodes once i expand another sub node:
HelpDocProblem
Could you implement it in a way that when a user CTRL clicks on a node to expand it that it collapses all others and without CTRL is keeps the expanded ones expanded ? This would keep the old functionality and adds the new one on demand.
thanks,
c.
