Rhino8 WIP Cycles rendering "flat" or not rendering
I have a problem with at least two latest builds, raytrace/cycles is not rendering as supposed. I got the error message below the viewport : " failed to load Cuda kernel from … (invalid kernel image)" , but the time counter keeps working
Rhino 8 SR0 2023-10-24 (Rhino 8 BETA, 8.0.23297.13303, Git hash:master @ 4368ce4c82870d4ce7b0ef004198da23d48ffe5f)
License type: Not For Resale Lab, build 2023-10-24
License details: Cloud Zoo
Expires on: 2023-12-08
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 5-26-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 5-29-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.75
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-29-2021
Driver Version: 27.21.14.6275
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.23297.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23297.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23297.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23297.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23297.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23297.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23297.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Hi @can.aysan
I’d start by updateing that driver - that’s almost 2 ½ years old. I that doesn’t do the trick, you might try the Repair option in the installer (Go to Windows Settings>Apps>Find Rhino in the list, the click Modify and choose Repair)
HTH, Jakob
PS Note that the Cycles kernel might take some time to compile the first time you run it - this is normal
Small clarification: this will happen only if you have an architecture that is newer than what precompiled kernels have been created for, or if you use OptiX. For such cases recompiles also may happen after driver update or Rhino update.
Thanks, driver update solved the problem. My machine has a fresh windows install, I never thought that the driver is outdated
Updates to Windows can mess up drivers, so after a Windows update it is good to reinstall drivers if you see unexpected behavior.
