Rhino8 - Properties Viewport Bug?
All I want is to have Properties and below Layers on the right side.
Have a look at what’s happening:
Hi Bogdan - is this what you are shootong for? I can’t quite tell what happens in your clip…
Try playing with them a bit more and you will run into trouble.
Obviously I managed to make it work as I want.
but, @pascal I have to admit that the way panels doc and undock is way better in Rhino 8. Having those blue squares to click into position.
Great job for Rhino 8
@Bogdan_Chipara I’m a bit confused what is happening in the first video you show. It looks like you have a copy of the properties window floating that gets ‘grayed out’ once it pops back in place in the docked area. Do you have ways to reproduce that behavior?
@Gijs , If I run into it again I’ll try to be more clear on how to reproduce .
