Hi I am having problems since last update (seemingly) - system run flawlessly since new build until this week.
Every time I try to open or edit the materials for a given layer the program crashes out completely. This happens on a model or a blank session of Rhino. Not had this kind of problem failure in 15years of using Rhino. Can anybody help with a fix or repair or has anyone else come across this?
It lags for 5 seconds at least while editing material- I thought it is a feature
before last week I had the same experience - lagged a bit then was ok - now not even working
Hello - are you running Flamingo?
Can you please run the SystemInfo command in Rhino and copy/paste the results here?
C-Fury Desktop sys spec 2021.txt (2.6 KB)
Hi Pascal try this
Hi Andy - 7.11 exposed a bug (in Flamingo) - for now, please revert to 7.10, I believe there is a fixed version of 7.11 in the works that will allow Flamingo to carry on as expected.
https://files.mcneel.com/dujour/exe/20210913/rhino_en-us_7.10.21256.17001.exe
I don’t have flamingo
and I’m facing it also
Hi Pascal,
thanks will do
I am not actually using Flamingo as 5.5 does not work well compared to the Rhino render function
But will revert and try
Many thanks
Hi Andy - you can just disable or uninstall Flamingo then, and keep 7.11.
Hello - Please run the SystemInfo command in Rhino and copy/paste the results here.
I just switched to rhino render but did not disable flamingo
Hi Pascal,
thanks will do - have uninstalled Flamingo and so far has not crashed
Rhino 7 SR12 2021-10-12 (Rhino 7, 7.12.21285.17001, Git hash:master @ 483b7829bea556f3f57cd592b5c685ea0f0a9521)
License type: Evaluation, build 2021-10-12
License details: Stand-Alone
Expires on: 2021-11-27
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [58% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 9-13-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.12
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-13-2021
Driver Version: 30.0.14.7212
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Thea For Rhino (0ab51401-0ca2-45e3-94e0-46d77b129353)\2021.3.2.0\Thea_V3\TheaForRhino7.rhp “Thea For Rhino”
C:\ProgramData\Beam\App\MKS\bin\RHINOBEAM.dll “MKS BEAM” 1.6.2.2
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “ConnectorRhino7” 2.2.2.7060
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot10RhinoPlugin (ccedd9da-83b9-429a-aec5-8ec90b85fe67)\1.2.0.0\KeyShot10RhinoPlugin\Rhino 7\KeyShot10RhinoPlugin.rhp “KeyShot10RhinoPlugin” 1.2.0.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 4.27.0.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ggKaramba\0.2.6.0\ggKaramba.rhp “ggKaramba” 0.2.6.0
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ggRhinoIFC\2.1.50.0\ggRhinoIFC.rhp “ggRhinoIFC” 2.1.50.0
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.2\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.2.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.12.21285.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.12.21285.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.12.21285.17001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.12.21285.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.12.21285.17001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.12.21285.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.12.21285.17001
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
Hello - you have quite an array of third party plug-ins. I would start by disabling all of those in Options > Plug-ins page, and then closing and restarting Rhno. Enable and load these one by one or in small groups, and see if you can figure out which, if any, is the bad guy.
