Now when using Search Mode. [my Normal mode on Mac since the beginning]
there is also a weird double thing popping up.
it look like the same bug as with the History mode
Edit: found out why this is happning , In Options > General, there’s always been [on Mac] the box to tick the command option dialog [the pop up]. so if this is on , It still bring up the option dialoge while the new Eto test is on.
So if you can deactivate it when the test command is running , or at least let Mac user know they need to turn this off manualy.
thanks a lot
