Rhino to Grasshopper: Mouse clicks, objects, views
Plugin and 4 userobjects components to receive:
    • All commands used in Rhino.
    • All objects added or removed.
    • Active view, cursor position and Mouse clicks.
    • Keyboard key pressed with its name (ALT, SHIFT, CTRL, TAB, SPACE, BACKSPACE, DELETE, ESC, ENTER).
With no need to use a timer.
I will share it after more tests.
New components:
  • Realtime mouse tracker and activeview.
  • Layers.
Interesting!
Test: Automatic Mesh outlines when the cursor moves
Components added:
  • Blocks
  • Enable/Disable events
Please get link for download this plugin
@Rh-3d-p
I will share it soon, just need more tests
Disable and Enable events will disable or enable sending data to all Grasshopper documents used the components, so we can create two Rhino buttons
The plugin uploaded to food4rhino, i will share the link when they validate it
Toggle button added, currently only one toggle works per document
Plugin available
https://www.food4rhino.com/en/app/rhinotograsshopper
Groups added
Adding point to canva when a point added to Rhino viewport
Ungroup, Explode block, Object selection
Very nice and useful. Here’s a suggestion, inspired by your last post: add a functionality to automatically add selected objects to the canvas in the proper batteries, with an option for automatically group them by type.
cheers!
The original idea was to use a screenshot of a Grasshopper script and place points on every component in the image, then convert all points to components in the canvas.
Anyway i can’t spend time on it, I showed an example and the user can do more.
I think adding components from Rhino will be a new plugin.
The command accept the name of the component and the Guid,
but the problem that i can’t find the list of all components or their guids.
We can add this command GhComponent to any Rhino button and assign a name or a guid, which add the component immediately to the canvas.
The idea based on code of: @piac
And @Mahdiyar
New components added
