Rhino to Blender (Mesh Bridge) import and export
Sometimes is useful to make corrections to the mesh inside Blender. To go back and forward between these two applications. And for this, thx to Rhino developers, I use just a button scripts.
Now lates version on GitHub
If you wish to improve it, it is now on GitHub
Here it is the Rhino Export command script to be added to a button. It will export to Blender:
! -_Export _GeometryOnly=_Yes _SaveTextures=_No _SaveNotes=_No _SaveSmall=_Yes
"X:\DoNotMove\Rhino-Blender-mesh.obj"
VertexWelding=Unmodified YUp=Yes enter enter
And the Rhino Import by clicking the right button. It will import from Blender:
! -_Import
MapYtoZ=Yes
enter
Then in Blender, you can use python
Rhino Blender Mesh Bridge Python V0.1 beta
# ~~~~~~ Alan Mattano 2020 SoaringStars lab
# ~~~~~~ Blender Rhino Bridge
import os
import bpy
def main1(context):
    print("Importing...")
    full_path_to_file = "X:\DoNotMove\Rhino-Blender-mesh.obj"
    # bpy.ops.import_scene.obj(filepath=full_path_to_file)
    bpy.ops.import_scene.obj(filepath=full_path_to_file, axis_forward='-Z', axis_up='Y', filter_glob="*.obj;*.mtl")
def main2(context):
    print("Exporting...")
    bpy.ops.export_scene.obj(filepath=full_path_to_file, use_selection=True)
class ImportOBJMesh(bpy.types.Operator):
    """Tooltip Import"""
    bl_idname = "myops.import_rhino_add_obj"
    bl_label = "Import Rhino OBJ Mesh"
    def execute(self, context):
        main1(context)
        return {'FINISHED'}
class ExportOBJMesh(bpy.types.Operator):
    """Tooltip Export"""
    bl_idname = "myops.export_rhino_selected_obj"
    bl_label = "Export OBJ Mesh to Rhino"
        main2(context)
        return {'FINISHED'}
# ~~~ end Import Export ~~~~~~~~~
class AMrhinoBridgeButton(bpy.types.Panel):
    """A Alan Mattano Custom Panel in the top bar viewport for importing and exporting files fast to Rhino"""
    ui_tabTitle ="------> Rhino Bridge <--------"
    ui_topHeader = "Rhino Import and Export tool"
    declare_filepath = "X:\DoNotMove\Rhino-Blender-mesh.obj"
    bl_label = ui_tabTitle
    # internal blender name
    bl_idname = "OBJECT_PT_rhinobridge"
    # place where will be the panle
    bl_space_type = 'PROPERTIES'
    bl_region_type = 'WINDOW'
    bl_context = "object"
    def draw(self, context):
        layout = self.layout
        # new line \n
        row = layout.row()
        row.label(text="Bridge", icon='MESH_CYLINDER')
        # new line \n
        row = layout.row()
        # BUTTON DELETE
        row.operator("object.delete", text="Delete Selected")
        # BUTTON IMPORT OBJ
        op = row.operator("myops.import_rhino_add_obj", text="IMPORT MESH")
        # BUTTON EXPORT OBJ
        op = row.operator("myops.export_rhino_selected_obj", text="EXPORT MESH To Rhino")
# ~~~ end Rhino Bridge Button ~~~~~~
def register():
    bpy.utils.register_class(AMrhinoBridgeButton)
    bpy.utils.register_class(ImportOBJMesh)
    bpy.utils.register_class(ExportOBJMesh)
def unregister():
    bpy.utils.unregister_class(AMrhinoBridgeButton)
    bpy.utils.unregister_class(ImportOBJMesh)
    bpy.utils.unregister_class(ExportOBJMesh)
if __name__ == "__main__":
    register()
This script will create an Import and Export button in the Object Properties section. To activate this button you need to select an object and then go to Object Properties. There you will find Import and Export buttons. There is extra code that is not needed. You can clean it. I will be creating a better version (plugin).
Rhino Blender Mesh Bridge Python V0.5 beta
Blender Plugin: Import only
bl_info = {
    "name": "New Rhino Object",
    "author": "Alan Mattano",
    "version": (0, 5),
    "blender": (2, 81, 0),
    "location": "View3D > Add > Mesh > New Rhino Object",
    "description": "Adds a new Mesh Object",
    "warning": "",
    "wiki_url": "",
    "category": "Add Mesh",
import bpy
from bpy.types import Operator
from bpy.props import FloatVectorProperty
from bpy_extras.object_utils import AddObjectHelper, object_data_add
from mathutils import Vector
class OBJECT_OT_add_object(Operator, AddObjectHelper):
    """Import a Rhino Mesh Object"""
    bl_idname = "mesh.add_object"
    bl_label = "Add Mesh Object"
    bl_options = {'REGISTER', 'UNDO'}
    scale: FloatVectorProperty(
        name="scale",
        default=(1.0, 1.0, 1.0),
        subtype='TRANSLATION',
        description="scaling",
        return {'FINISHED'}
# Registration
def add_object_button(self, context):
    self.layout.operator(
        OBJECT_OT_add_object.bl_idname,
        text="Add Rhino Object",
        icon='PLUGIN')
# This allows you to right click on a button and link to documentation
def add_object_manual_map():
    url_manual_prefix = "https://discourse.mcneel.com/t/"
    url_manual_mapping = (
        ("bpy.ops.mesh.add_object", "rhino-to-blender-mesh-bridge-import-and-export/94448"),
    return url_manual_prefix, url_manual_mapping
def register():
    bpy.utils.register_class(OBJECT_OT_add_object)
    bpy.utils.register_manual_map(add_object_manual_map)
    bpy.types.VIEW3D_MT_mesh_add.append(add_object_button)
def unregister():
    bpy.utils.unregister_class(OBJECT_OT_add_object)
    bpy.utils.unregister_manual_map(add_object_manual_map)
    bpy.types.VIEW3D_MT_mesh_add.remove(add_object_button)
    register()
Rhino Blender Mesh Bridge Python V0.7 beta
Blender Plugin: Blender script side for import and export.
bl_info = {
    "author": "Alan Mattano, Soaring Stars lab",
    "version": (0, 7),
    "warning": "",
    "wiki_url": "",
import bpy
        return {'FINISHED'}
        icon='PLUGIN')
class OBJECT_OT_add_objectexport(Operator, AddObjectHelper):
    bl_idname = "mesh.add_objectexport"
    bl_label = "Save Mesh Object"
        return {'FINISHED'}
def add_objectexport_button(self, context):
        OBJECT_OT_add_objectexport.bl_idname,
        text="Save Rhino Object",
        icon='PLUGIN')
# Registration
def register():
    bpy.utils.register_class(OBJECT_OT_add_objectexport)
    bpy.types.VIEW3D_MT_mesh_add.append(add_objectexport_button)
def unregister():
    bpy.utils.unregister_class(OBJECT_OT_add_objectexport)
    bpy.types.VIEW3D_MT_mesh_add.remove(add_objectexport_button)
    register()
Thanks for sharing very works perfectly
Did you change directory file adress in blender? Because my Blender coulnd’t find the file and gave an error.
I do not remember. This is for Windows. And you must change the full path inside the script to much your directory full path(directory file address).
As well as in the Rhino button.
Let me know if is not working or not clear.
