Hi guys,
I have been trying to set the Rhino-Render Background Color using Grasshopper and python.
I tried:
rs.RenderColor( render_background_color, (187,187,187) )
So far its been unsuccessful. Do you have an idea if that works?
Thanks!
Daniel
Hi guys,
I tried:
Thanks!
Daniel
Try setting the script context to the Rhino document:
Magic, that helped! Thank you very much!
No worries. Also, note that you probably don’t need the rs.EnableRedraw() calls in your case. Since you’re not iteratively e.g. adding geometry or fiddling with layers.
