JinLong
(JinLong)
November 27, 2025, 9:02am
1
Hi all,
After updating RIR to the latest version (1.33.9347.9430), I received a warning, and Grasshopper no longer works. However, when I roll back to version 1.32.9327.20567, everything works normally.
Should I continue using the old version, or is there another solution?
Pls see the screenshot below.
Thanks.
Revit version is 2023.1.8
Rhino version is 8.25.25328.11001
MSAwan
( Muhammad Saqlain Awan)
November 27, 2025, 5:06pm
2
Hi @JinLong ,
Uninstall and Re-install the Plugin. I also had this issue but now it works.
JinLong
(JinLong)
November 28, 2025, 12:56am
3
Hi, @MSAwan
I tried to uninstall and reinstall it several times, and still have problems.
I used the previous version first.
Thanks.
Hello Jin! Could you please upload the previous version?
scottd
(Scott Davidson)
December 17, 2025, 10:11pm
5
Is it possible the 3dm does not have any Units? Technically they are possible to make.
If in Revit, bring up the Rhino. Check Tools > Options > Units. What does it read?
Japhy
(Japhy)
December 17, 2025, 10:21pm
6
A repair install of Rhino.Inside.Revit may resolve this as well. Go to Add or Remove Programs>Modify>Repair
kike
(Kike Garcia)
December 18, 2025, 5:46pm
7
Hi @JinLong
This issue is solved on v1.35 of RiR.
JinLong
(JinLong)
December 19, 2025, 12:47am
8
Hi all,
Thank you all for your replies. I’m looking forward to the release of the official version.
JinLong
(JinLong)
January 30, 2026, 8:13am
9
Hi all,
This issue is solved on RhinoInside.Revit_1.35.9525.16240
