Life_Dj
(Life Dj)
March 29, 2024, 7:00pm
1
I created the two geometry in Rhino and sent them to Revit using rhino inside revite, but I can only see part of it on Revit, except for what is under 1.2 meters…and I want to see the entire shape without affecting the cut plane of the project
Japhy
(Japhy)
March 29, 2024, 7:29pm
2
Hi LifeDj.
I changed the forum category of your post to Rhino.Inside - Revit, please do so when you post questions concerning Rhino.Inside.Revit. Thanks.
Can you provide more detail on the issue? not quite understanding it from the images. Thanks.
4. Isolating the issue and posting files
Revit projects are rarely small & the issues are rarely simple. Its understandable that support files aren’t always readily uploadable, for size or for privacy concerns.
That said, here are some recommendations:
Isolating the question to a new Revit file with the Revit Version in the File Name, then purge the Revit file several times to reduce size.
List your GH plugins needed to review the question, if possible remove all gh plugin components no…
