Rhino inside revit 2025 message > Rhino is not available
When starting Revit 2025.
Message Rhino is not available Rhino.inside Revit requires Rhino 7 or 8 installed on the computer.
Rhino.Inside - Install Rhino
Rhino 7 is installed.
No problems in Revit 2024
Rhino.Inside - About revit 2024
Hi @Peter_Vlug_Inbo,
The message should be improved, but Rhino.Inside Revit 2025 requires Rhino v8.0.
@kike
Thanks for the answer.
That was something we already suspected
Revit 2025 went to .NET Core 8.0. This means the Rhino also needs to run within the newer .NET Core, which is Rhino 8.
