RogerD
July 22, 2025, 9:51pm
1
Hi all,
Does anyone any info on the rhino common command below, I cannot find it in the documentation or any example of it .
I assume if it works it would constrain the closest point to the face and not use the brep edge unlike Brep.ClosestPoint or am I being stupid.
Rhino.Geometry.BrepFace.ClosestPoint()
dale
(Dale Fugier)
July 22, 2025, 10:23pm
2
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.surface/closestpoint
BrepFace does not implement a ClosestPoint override. Thus, when you call ClosestPoint on a Brep face, you’re actually calling ClosestPoint on the Brep face’s underlying (untrimmed) surface.
Keep in mind that BrepFace inherits from Surface .
So no, BrepFace.ClosestPoint does not deal with Brep edges.
Note, if you want to know if the results BrepFace.ClosestPoint fall in the active region of the face, use BrepFace.IsPointOnFace .
– Dale
