when i try to create a new empty document by chosing a Template, i use:
File > New Using Template…
which opens the Splash screen which has the list of standart Templates on the right. I do not want to choose a Standart Template but one of my own files which is not in Rhino’s Template directory. If i click on the button Open Other… i can navigate to my own Template file but it is opened as file not as new empty untitled file. So if someone saves over this, he destroys my template.
It would be great to have a button in the dialog which allows to open a Template file from a different location, same as it is possible under Windows. Here i can just run _New and get asked for a template to use. If i do the same under Mac, it just opens a new empty file with a Template i never specified.
since the problem still happens in Rhino 8 for Mac i want to point out a related issue which results in an accidentally overwritten template file even when the user never saved.
If you do the procedure as decribed in the opening post and asume you’re opening a file as template file by choosing Open Other… and you choose a Rhino file which was written in Rhino 7, you’ll get a warning message that Autosave will be disabled in Rhino 8 for Mac. However Autosave does not get disabled, in case of a crash it will indeed overwrite the file.
I wonder why Rhino for Mac does not behave like the Windows version when it comes to templates ?
