So, lately i´ve been working on Rhino and Autocad alternately, and since I´ve been figuring out some problems with the file exportation (PDF or even .dwg files).
As you can see on the uploaded images everything looks smooth and perfectly fine on Rhino, but soon as I export the file to PDF or .dwg (even with REGEN command) many lines look kinda shaky and not smooth at all as you can see. I can tell that for a distance, it kinda looks everythings fine, but when I zoom its not at all.
Can anyone tell me if I am doing something wrong? Is this normal?
Is it something related with the Rhino options/definitions?
Hi there, your export scheme for the dwg is set on default? maybe you have activated an other export scheme.
go to export - options - edit export schemes, have a look at “rhino objects” vs “auto cad objects”, there should be written that rhino curves are converted to auto cad splines.
Thank you Julian
I had this settings on the exportation, I have tryed some different schemes to find the right one but it seems that I´m having the same problem. Is it possible to be related with the curve tesselation parameters?
