Rhino can run headlessly only, inside Java
Issue
I was trying to run Rhino.Inside inside Java 8 using jni4net as the bootstrapper. It didn’t work with the following code:
Core = new RhinoCore(new string[] { }, WindowStyle.Normal);
after ~3 seconds of execution, an exception pop up: InteropServices.COMException: 'Error HRESULT E_FAIL has been returned from a call to a COM component.' Error code (0x80004005).
However, Rhino.Inside runs without window by:
Core = new RhinoCore(new string[] { }, WindowStyle.NoWindow);
RhinoCommon is soon usable, but this defys the original intent of using Rhino.Inside.
Environment
  • I am using the latest 7.3.
  • Rhino Inside Revit runs normally.
  • JRE 8 is 64-bit
Question
I can use interprocess communication but I found Rhino.Inside might be more interesting.
Any idea on this issue or how to debug such a situaiton?
Code
Java code & binary: eclipse-workspace.zip (333.9 KB). Run rhinoInsideJava.bat. Make sure you have 64-biyt JRE 8 in PATH.
C# source for reference: McLivelink.zip (4.9 KB)
rhino.exe is never loaded into a Rhino.Inside project. RhinoCore.dll is what gets loaded.
Rhino.Inside only works with 64 bit processes. This is also something you need to check.
I checked it was hosted in 64-but process. Forgot to mention :zipper_mouth_face:
:slight_smile:
You might want to try WindowStyle.None. It may be that Rhino.Inside will currently only work in a headless mode for minecraft
You are right. Rhino.Inside is only able to run headlessly, in a Java program (not specifcally Minecraft). :thinking: Hopefully the limitation can be overcome…
Provided a much simpler example
