Capturing Viewport causing unexpected results, when the viewport is scaled X3
I can’t tell from that image what is unexpected
Hello @stevebaer
If you look at the blue box you can see a difference in the lineweights of the sunpath symbol.
hi @tay.othman do you have a (simple) model you can share that shows this behavior?
Does this happen in a specific mode or in any mode?
Hello @Gijs it has been 3 builds since I got the issue, I’m trying again without the possibility of re-creating the issue. so I assume it was silently solved or fixed.
Otherwise, I can still reproduce the issues mentioned in the post below whenever I export view captures larger that the viewport’s resolution.
Rhino 8 - Viewport Capture to File Issues List - Serengeti (Rhino 8 BETA) - McNeel Forum
