Exporting fast and accurate data can dramatically reduce production errors and on the other hand increase productivity.
Here with this grasshopper script, you can export a cutting file with all the necessary production info marked on it by simply selecting the appropriate parts.
In this version 2 you can select multiple parts at the same time and let the script do all the work. You may group the plates with the same thickness and run the script so you have also grouped output files.
Enjoy!
Any feedback is more than helpful. In the below link you can find a preview for the Plate Markings v2.
