Rhino 9 WIP Available Now!
Rhino 9 WIP (9.0.25273) is now available for Windows and Mac
Bugs Fixed:
  • ClippingDrawings: Projection always resets to Parallel (RH-89607)
  • Display: Options UI:
    • Edge color gets reset (RH-89624)
    • Color backface does not work in Display panel (RH-89601)
  • Mirror: Mirror creates bugged object (RH-89458)
  • OSnap: Quad and Mid don't show simultaneously (RH-89604)
  • SoftTransform: SoftTransform should work with cage objects (RH-89452)
  • Thickness: Allow More Decimals (RH-89564)
  • Zebra: Removed "Distance" mode as it could not reveal discontinuities (RH-89635)
Enhancements:
  • Drag Settings: Made Soft Transform work with UVN mode (RH-56770)
  • File IO: SketchUp Export - Added "Group objects" option to make selecting objects in SketchUp easier (RH-89556)
Features Added:
  • ClippingDrawings: Added Projection=Reflective for drawing Reflected Ceiling Plan (RH-77428)
Regressions Fixed:
  • SelName: [Enter] does not close the dialog (RH-89656)
Usability Problems Fixed:
  • ScriptEditor: Right-click cut, copy, paste in Script Editor for Windows (RH-79242)
Windows-Only Changes
Bugs Fixed:
  • Display: Direct3D:
    • Inverted inactive technical detail views with shadows… (RH-89647)
    • Normal map producing wrong results for transparency (RH-89573)
    • Some isocurves missing on NetworkSrf preview surface (RH-89431)
