Rhino 9 potential bug
potential Rhino 9 (9.0.26251.12303, 9/8/2026) trim bug:
FilletSrf
trim resulting surface with plane of symmetry
explode resulting fillet surface
extend resulting fillet surface with extendSrf
trim FAILS with two surfaces And with the surface & line of intersection And with the surface & extended dupedged edge… see image below and included file
Rhino 9 potential bug.3dm (37.6 KB)
Hi @artesmith,
You posted an empty .3dm file.
– Dale
sorry!
Rhino 9 potential bug.3dm (805.6 KB)
Hi Artesmith -
Thanks.
→ RH-98856 Trim: Failure Case
what’s the prognosis on RH-98856 ?
Art
The best prognosis is its release target, which is currently set to Future. Future generally means ‘not anytime soon’ but release targets also change over time.
If you need a workaround: use SrfSeam to move the surface seam of the surface away from the intersection curve
