Rhino 9 BETA 9.0.26195.12303
Dark Mode appearance not working as seen below. Only some fields present dark.
quick test here was fine. Lets run the Reset command and Restore to default settings, then try dark mode again. If unsuccessful run Systeminfo in the Rhino command and post the results.
Reset worked! Even though it was a fresh install… But, thank you!
The reason why this can happen is because colors that are overridden (eg Content.Background, Frame.Background) are not automatically reset when switching between modes.
In your screenshot both mentioned colors seem to have overrides. If this happens again look in advanced settings to look up those colors and set them back to default.
I’m not 100% sure what would be best here to do. But it probably makes sense that switching to dark or light mode should at least reset those two colors.
