Rhino 9 AI error
Rhino has a connection with codex and the MCP is installed and linked. whenever using the AI panel and entering a prompt it always returns “error: Codex process exited.” in the command bar. I can use the separate cmd program to use codex in Rhino 9, but this is an issue I’m running into and cannot figure out how to resolve it.
Are you trying to use your own mcp in the Rhino ai panel?
I tried using my own mcp too and ran into a codex error as well. Fixed it using llms, this was it’s solution:
The panel runs Codex with its own CODEX_HOME (%APPDATA%\RhinoAI\Codex) and copies only auth.json. So do codex login first, and add MCP servers in AI Settings → MCP Servers, not in ~/.codex/config.toml. The default model gpt-5.5 is refused on ChatGPT-plan accounts, so select a model your account supports. For a server that needs auth, use “bearer_token_env_var”: “MY_TOKEN” and set that variable before Rhino starts. Codex drops headers objects, so the server rejects the call. The type is ignored warning is harmless.
Maybe try copying that to your agent to fix it if possible!
