Rhino internal AI editor can't connect to my agent
Over here, the Rhino internal-AI editor lost the connection with my Claude agent.
Has anyone an idea how I can repair this?
Dag Gerard -
We have that issue on the list as RH-99857 RhinoAi Install instruction for Claude Desktop failure
It looks like Michael was able to get around that:
Ah, thanks Wim for your swift reply.
I look at Michael’s solution later then.
Mine had issues conecting because at some point I had Claude Code CLI and Codex CLI installed and rhino seens to have catch some of those old uninstalled softwares in favor of the newer desktop variants.
I fixed by reinstalling the CLI versions and just using them instead for now. However, after I started the MCP server and restarted Claude Desktop it was able to point to that instead of the CLI version. I ended up just prefering to use the Claude desktop instead of the AIPanel just so I could send command from my phone while away from computer :slight_smile:
This way I was both working on cleaning the kitchen and 3d modelling :stuck_out_tongue:
Thanks to @Gijs de Zwart, there was another solution to solve the problem.
In the powershell, copy/paste: irm https://claude.ai/install.ps1 | iex
then press enter
Step by step:
Get to the power shell
Run the command
