Rhino 8 WIP Available Now!
Rhino 8 WIP (8.0.23031) is now available for Windows and Mac
Bugs Fixed:
  • FilletSrf: Surface was trimmed when Extend option was off (RH-72361)
  • Gumball:
    • Extrude handles displayed when selected object could not be extruded (RH-72673)
    • Extrude dot did not appear on SubDs (RH-72210)
  • Rendering: Tone mapping, color and intensity did not match between Rendered and Raytraced viewports (RH-72512)
  • RhinoCode: Python initialization failed due to space in path (RH-72386)
Enhancements:
  • UDT: Indicates UV and XYZ direction when setting degrees and point counts for rectangular and box cages in CageEdit and Cage commands (RH-28254)
Regressions Fixed:
  • StatusBar: No relative coordinates in info pane (RH-71467)
  • Viewports: Viewports - crtrl-tab does not cylce the views (RH-72529)
Tasks Completed:
  • Templates: Perspective viewport uses Shaded display mode by default (RH-70700)
Rhino 8 WIP (8.0.23038) is now available for Windows and Mac
Bugs Fixed:
  • CPlane: AutoAlign: Added "Sticky" setting to Auto CPlane pane menu (RH-72742)
  • Copy: Cage captive object in group stayed in original group when copied (RH-72746)
  • Gumball:
    • Unexpected position on clipping plane (RH-72770)
    • Extrude numerically did not work with SubD (RH-72628)
  • MatchSrf: History did not update properly when both surfaces were moved together (RH-72666)
  • MergeAllCoplanarFaces: Could not be cancelled (RH-70178)
  • Select: Selecting single custom object reports incorrect type (RH-72837)
Enhancements:
  • Properties: Display color can be assigned to faces on an Extrusion object. The outcome is a polysurface. (RH-58009)
  • Rendering: Textures: Added "Disable" to "Texture Bake Quality" drop-down menu in Render properties (RH-66234)
Features Added:
  • Block: New SelMirroredBlocks command (RH-72549)
Usability Problems Fixed:
  • ReplaceBlock: ReplaceBlock - make it scriptable (RH-72651)
Mac-Only Changes
Bugs Fixed:
  • NamedView: Named Views panel did not work on Mac (RH-72744)
Windows-Only Changes
Enhancements:
  • Gumball: The size is scaled by screen DPI setting on Windows (RH-72125)
Regressions Fixed:
  • Gumball: Did not show on selected object in an active detail (RH-72689)
Rhino 8 WIP (8.0.23045) is now available for Windows and Mac
Bugs Fixed:
  • MatchProperties: Match in Materials deselects object (RH-72116)
  • OSnap: Rhino.Options.ModelAid.SnapToOccluded is broken (RH-72252)
  • RhinoCode: Python lists do not cast to IList when calling managed methods (RH-72933)
  • WindowLayout: Workspaces: Hide/Show a panel with a macro - ref. RH-35026 (RH-68484)
Crashes Fixed:
  • Offset: crash when trying to offset a planar curve (RH-72895)
Rhino 8 WIP (8.0.23052) is now available for Windows and Mac
Bugs Fixed:
  • Meshing speed (RH-72571)
  • Display: Selection silhpouette highlight tuneups (RH-73006)
  • Gumball:
  • SDK: RhinoCommon ProjectPointsToMeshesEx issue (RH-72990)
  • Trim: Slow edge remapping (RH-73033)
Mac-Only Changes
Bugs Fixed:
  • Display Metal:
    • Layout detail was wrong and changed when panning (RH-72849)
    • Detail view was black in new layout (RH-73010)
  • Menu: The command editor is obsolete (RH-72303)
  • Rendering: raytraced and rendering give different results on Mac (RH-72682)
Bugs Fixed:
  • Rendering: Environments: Missing the crystal ball in OpenGL previews (RH-72897)
Rhino 8 WIP (8.0.23059) is now available for Windows and Mac
Bugs Fixed:
  • LayerStateManager: Layer State restore issue (RH-73238)
  • Options: ETO Appearance: make sure all items work (RH-72195)
  • RhinoCode:
  • Layer: "Layer On in this Detail Only" is made available on context menu of every column when a detail view is active (RH-71217)
  • RhinoCode:
    • Code editor to print stdout to Rhino console like existing Rhino Python Editor (RH-72918)
    • Add autosave on run option, just like the Python Editor does. (old habits are difficult to change, so maybe have this as an option in Preferences) (RH-72917)
Mac-Only Changes
Bugs Fixed:
  • MacroEditor: Macro Editor double quotation marks depend on system settings (RH-73307)
Rhino 8 WIP (8.0.23066) is now available for Windows and Mac
Bugs Fixed:
  • 4View: Projection option (RH-73266)
  • Gumball: Extruding planar polysurface edges with the gumball should boolean the extruded surface (RH-73138)
  • Paste: Doesn't work in macro (RH-72471)
  • Rendering: Materials: Rhino crash when switching from PBR to plaster (RH-72828)
  • Rendering: Realtime SDK: Suboject material problems in the changequeue (RH-73067)
  • RhinoCode: scriptcontext.escape_test() not working (RH-72484)
  • SelBoundary: Failure case (RH-73387)
  • Selection:
    • Deselection glitch (RH-73197)
    • Interior (invisible) vertices and edges of n-gons were pickable in wireframe mode (RH-36481)
    • Edges on back of mesh/SubD could be selected in Shaded mode (RH-73338)
  • StatusBar: Layer pane did not show layer path for sub-layers (RH-73287)
Crashes Fixed:
  • Panels: Crash when switching between panel tabs (RH-73399)
Regressions Fixed:
  • Picture: Missing 1To1 option in command-line (RH-73376)
UI Change:
  • Rendering: Presets: Added "Custom" to Presets dropdown menu (RH-73371)
Rhino 8 WIP (8.0.23073) is now available for Windows and Mac
Bugs Fixed:
  • Moving separator crashes Rhino instantly (RH-72215)
  • Annotation: Hatch: Display: Selected control polygon of hatch (RH-73556)
  • ClippingPlane: Edge color is used for fill (RH-72468)
  • Detail: From Detail - projection option (RH-73267)
  • Display: Display mode curve thickness - II (RH-72900)
  • FilletSrf: Preview has fillet but final result does not (RH-73567)
  • Fin: Fin bahavior (RH-73473)
  • Layer:
    • Layers panel stole focus from command-line when typing command (RH-71036)
    • Layers panel - column dragging issue (RH-73407)
  • OSnap: Snap To Occluded is broken (RH-72252)
  • RDK: Eto UI - Dragging slider saved far too many undo records (RH-72530)
  • Rendering: Custom preset made the scene bright (RH-73369)
  • Rendering: Cycles Viewport:
    • HUD controls incorrectly displayed tooltips in Toast (RH-73412)
    • Hidden geometry got rendered in Raytraced mode (RH-73439)
  • Rendering: Materials: Materials: Set rendering color command problems (RH-72875)
  • Rendering: Realtime SDK: Rendering was continually being restarted when dragging material to Raytraced viewport (RH-73498)
  • Rendering: Texture Mapping: Delete Mapping needlessly asked for a reselection of the object and a channel (RH-72198)
  • RhinoCode: ScriptEditor: Tracking break points saved to file did not work (RH-73374)
Enhancements:
  • Point Filters: Allow single number entry when .xy point filter is activated (RH-73501)
Regressions Fixed:
  • File IO: Closed objects exported to SKP incorrectly as open objects (RH-73480)
  • Print:
    • Curves to PDF (RH-73443)
    • Print widths inconsistent between Rhino 7 and Rhino 8 (RH-72105)
UI Change:
  • Layout: Added descriptions to all "Initial Detail Count" numbers (RH-73432)
  • Display: PrintWidth shows in Display without (PrintDisplay=On) (RH-33587)
Mac-Only Changes
Bugs Fixed:
  • ClippingPlane: Clipping planes in metal behave unexpectedly with annotations (RH-72290)
  • Display Metal:
    • Objects selected in an active detail view did not show Gumball (RH-72815)
    • Layout: Zoom behavior is off (RH-72949)
    • Meshes did not display in detail views (RH-72610)
    • Hatch shows through objects (RH-72932)
  • File IO: PLY import scaled incorrectly on macOS (RH-73477)
Enhancements:
  • RhinoCode: Script Editor allows opening file from explorer window by drag and drop (RH-73409)
Rhino 8 WIP (8.0.23080) is now available for Windows and Mac
Bugs Fixed:
  • BlendSrf: BlendSrf updates incorrectly (RH-53677)
  • ClippingPlane: Snap points on clipping geometry disappeared at some locations (RH-72025)
  • Display:
    • No point feedback on clipped side of clipping plane (RH-70920)
    • Orthogonal curves displayed thinner (RH-73474)
  • Display Metal: Metal: Clipping Planes clip Isocurves only (RH-72721)
  • File IO: Print or Export gradient hatch as black and white (RH-71090)
  • Properties: Custom mesh did not use document mesh settings as default (RH-73460)
  • PushPull: PushPull does not find regions when face is split by several open curves (RH-73613)
Crashes Fixed:
  • Mapping widget command: Deleting locked up Rhino (RH-73564)
Enhancements:
  • SubD: Sharp command - usability enhancments (RH-73650)
Mac-Only Changes
Bugs Fixed:
  • Display Metal: Clipping planes don't work with Metal (RH-72288)
Cosmetics:
  • Display Metal: Diagonal lines appeared thicker (RH-72695)
Bugs Fixed:
  • Display: Wires looked thicker in Rhino 8 on low DPI screens (RH-72772)
Regressions Fixed:
  • OffsetSrf: Incorrectly splits the output surfaces (RH-45266)
UI Change:
  • Selection: Renamed "Allow window selection of sub-objects" option to "Allow selection of sub-objects" (RH-73606)
Rhino 8 WIP (8.0.23087) is now available for Windows and Mac
Bugs Fixed:
  • BlendSrf: editing restores controls to defaults (RH-67831)
  • Display Metal:
    • Texture failed in Rendered mode #2 (RH-73538)
    • Texture failed in Rendered mode (RH-73537)
    • Black lines on viewport borders (RH-73241)
  • File IO:
    • Displacement render meshes did not export to glTF (RH-73581)
    • Export Selected did not save geometry to glTF (RH-73632)
  • Inset: Inset creates small loop (RH-73772)
  • OSnap: ClippingPlane causes issues with Osnap (RH-73739)
  • Rendering: Textures: Repeat sliders and negative numbers (RH-73352)
  • RhinoCode:
    • rs.AddLayer fails (RH-73563)
    • C# diagnostics gets really slow (RH-72969)
    • script fails to finish, ok in RunPythonScript (RH-72454)
  • SoftTransform: SoftTransform command gives no radius preview sphere when in box mode (RH-73673)
  • Toolbar: New toolbars in v8 did not display LMB and RMB icons in the tooltips (RH-68818)
Enhancements:
  • GetPoint: Object draw color when in "Print Preivew" mode uses layer color (RH-73756)
  • Inset: Failed on a specific case (RH-73722)
Mac-Only Changes
Bugs Fixed:
  • Display Metal:
    • Metal: Demanding pixel shaders can “snowball” Rhino down to 1 FPS (RH-73656)
    • Metal: Overlay drawing becomes very sluggish (RH-73805)
    • Metal: Arctic should ignore the skylight enabled/disabled setting (RH-73804)
    • PBR objects render black if shadows were disabled (RH-73614)
Rhino 8 WIP (8.0.23094) is now available for Windows and Mac
Bugs Fixed:
  • CommandPrompt: Floating command prompt window was closed on next start-up (RH-73767)
  • Curve: Self intersecting curve not detected (RH-73966)
  • Display Metal: Decals did not show up (RH-71407)
  • History: Dim on layout moves far away when detail is activated (RH-73916)
  • Layer: : Keep scrollbar movement on scrollbar (RH-73838)
  • Localization: AutoAlignCplane command did not accept English options (RH-73885)
  • Ortho: Z-ortho snap issue (RH-73327)
  • PushPull: Setting OSnaps locked up Rhino (RH-73640)
  • RhinoCode:
    • “Restore Packages” step should lock the UI so user can not make changes that changes script behaviour (RH-73915)
    • Scripts attempt to install packages on every run. This is very slow (RH-73914)
  • UnjoinEdge: Did not detach vertices when needed (RH-73908)
  • Unwrap:
    • Unwrap - selection is lost on display mode change (RH-65713)
    • do not highlight occluded edges during seam selection (RH-68855)
Enhancements:
  • Options: Fix up scale dialog when changing the unit system (RH-73876)
  • SubD Editing: SubDSpinEdge command - Added SpinEdgeAgain and Undo options and tuned up workflow (RH-73773)
Mac-Only Changes
Bugs Fixed:
  • Display Metal: SubD faces highlight yellow in OpenGL but not Metal (RH-69508)
  • RotateView: Trackpad on Mac stopped working correctly after laptop sleeps (RH-70694)
  • Viewports: Two-finger gesture rotate stopped working (perspective view) (RH-71088)
Features Added:
  • Layer: Deleting multiple layers with objects prompts deleting one-by-one or all at once (RH-36677)
Bugs Fixed:
  • Grasshopper 2: Doesn't load past 7% when display is scaled at 150% (RH-72064)
Enhancements:
  • Eto: Made search box in panels more discoverable and friendly (RH-69333)
Rhino 8 WIP (8.0.23101) is now available for Windows and Mac
Bugs Fixed:
  • Block:
    • Block definition out of sync with model scale with units change (RH-65016)
    • One of transform values in block instance properties could not be reset (RH-73995)
  • Display:
    • Array preview with silhouette highligjhting (RH-74104)
    • Viewport border highlight when selected object is bigger (RH-73574)
  • DupBorder: DupBorder on subd subobjects does not join the curves (RH-52346)
  • HighlightObjectLayers: HighlightObjectLayer: scroll the layer into view (RH-74063)
  • Layout: Dimensions moved after exiting detail (RH-74008)
  • MouseOver Highlight: Difficult to pick ambiguous edges (in MatchSrf) (RH-73994)
  • RhinoCode: ScriptEditor: Slow to open (RH-73250)
  • SDK:
    • Mesh.Smooth is slow when used in a loop (RH-71530)
    • Mesh.Smooth does not yield same results as Smooth command (RH-71529)
  • Selection: Silhouette is confusing and obscuring pick feedback (RH-73755)
  • SubD: Sharp edges: Gumball editing SubD sharp edges causes unexpected jumping of vertices (RH-73780)
Enhancements:
  • Layer: Filter expands to filtered names (RH-73777)
Mac-Only Changes
Bugs Fixed:
  • Display Metal: Selection silhouette looks odd when rotating object (RH-74007)
Rhino 8 WIP (8.0.23108) is now available for Windows and Mac
Bugs Fixed:
  • BlendSrf: Planar sections lost on edit (RH-68340)
  • BlockManager: Show top level items by default (RH-70247)
  • CPlane: AutoAlign: Auto Align CPlane should align to blocks, mesh faces, subd faces (RH-74183)
  • Dark Mode: DarkMode: Dark mode side bar is messy (RH-71186)
  • Gumball: Gumball- DimAngle glitch (RH-73508)
  • Line: Normal line drawn from picked surface or adjacent surface randomly (RH-74224)
  • MacroEditor: Editing a Duplicated button alters it's 'parent' (RH-73796)
  • MacroLibrary: Toolbar button duplicate icon replaced the icon of the parent (RH-73803)
  • MatchSrf: MatchSrf - Show the points in the preview (RH-46290)
  • PushPull: Failed to merge faces (RH-73066)
  • RhinoCode:
    • ILegacyDocument is missing Objects (RH-74259)
    • Script Editor crash on open (RH-74169)
  • SDK: RhinoCommon: Add Mesh.SubDivide and Mesh.SubDivideFace methods to RhinoCommon (RH-74168)
  • Selection: Ctrl Window-Deselect is broken for subobjects (RH-74243)
  • Smooth: Smooth command dialog missing title bar text (RH-74200)
  • SubD: Sharp edges: Shaded display mesh can sometimes not match SubD wires after Sharp (RH-73779)
  • WindowLayout: Editing a Macro on a Toolbar Button doesn't update (RH-70882)
Cosmetics:
  • UI Appearance: Mouse icons missing from popup toolbar mouse-over (RH-73337)
Enhancements:
  • MatchSrf: Show the control points on the previewed surface (RH-74233)
Regressions Fixed:
  • DocumentProperties: Changes to display precision do not stick (RH-74242)
UI Change:
  • SubDSphere: Added all sphere creation options (RH-74179)
Bugs Fixed:
  • Edit Macro icons in Rhino Light Mode have a dark background when Windows is in Dark Mode (RH-72217)
Rhino 8 WIP (8.0.23115) is now available for Windows and Mac
Bugs Fixed:
  • Annotation: DimLinear: Dimension with Mask Not Using the TextGap (RH-71452)
  • Block: Block Instance properties resets position of multiple selected instances (RH-74084)
  • BlockManager: Blocks panel shows empty units dropdown for unitless definitions (RH-74028)
  • CPlane: Rotated 90 degrees when set to ClippingPlane object (RH-74367)
  • ExtendSrf: ExtendSrf extends surface in more than one direction (RH-74088)
  • ExtractMeshFaces: ExtractMeshFaces needs SelBrush support for visible faces only (RH-42731)
  • Menu: Toolbar Layout menu option is obsolete (RH-74393)
  • Mesh: Opening custom mesh settings on an object making no changes, triggers a scene remesh (RH-74191)
  • RhinoCode: CPython should keep using the same scope for a script instance like legacy Python (RH-74305)
  • SDK: RhinoCommon: Unable to move edges within face tolerance, nothing done (RH-71087)
  • SetDimensionLayer:
    • Cannot type an existing layer name (RH-74335)
    • First Pick on “UseDimensionLayer=No” Behavior (RH-74336)
  • Toolbar: Can't delete toolbars from Tools>Toolbar Layout (RH-72461)
Enhancements:
  • OffsetCrvOnSrf: Pick location to define offset direction with OffsetCrvOnSrf (RH-73619)
  • SelBoundary: SelBoundary fails on hatch (RH-74414)
Regressions Fixed:
  • Display: Objects turn black (RH-65618)
Mac-Only Changes
Bugs Fixed:
  • DocumentProperties: Changing file units doesn't work (RH-74085)
Bugs Fixed:
  • Display: hidden edges are drawn over objects (RH-74292)
Rhino 8 WIP (8.0.23122) is now available for Windows and Mac
Bugs Fixed:
  • BlockManager: Writing in the Description field (RH-72181)
  • CPlane: AutoAlign: Gumball flips (RH-74194)
  • Display: Text points visible but not selectable (RH-74429)
  • Gumball:
    • gumball scale handles not accepting text input (RH-74357)
    • Gumball Bunnytail color (RH-74235)
  • Layer: Bulb half lit when moved up a parent (RH-73361)
  • PushPull: Allow preselection (RH-74453)
  • RDK: Environment preview image squashed at non-100% scaling (RH-69323)
  • SubD: Sharp edges: SubD Sharp info is lost when splitting an object (RH-73860)
  • Toolbar:
UI Change:
  • Options:
    • Scripted Options and DocumentProperties commands don’t sort command line options (RH-74481)
    • Add CPlane axis option to scriptable View options (RH-45754)
  • Insert: -Insert Does Not Offer Options for Block Conflict Resolution (RH-69709)
  • Rotate3D: Selected surface normal (RH-54370)
Bugs Fixed:
    • Crash when pasting a custom material from Rhino 7 to Rhino 8 that has the same name (RH-72036)
    • Material editor right click in search shows sort of empty tooltip (RH-74372)
Rhino 8 WIP (8.0.23125) is now available for Windows and Mac
Bugs Fixed:
  • BlockManager: Preview orientation (RH-72712)
  • Crash: Crash when displaying the notifications panel (RH-74620)
  • Gumball: Gumball Bunnytail color (RH-74235)
Bugs Fixed:
  • Display: Some environment is shown in viewport (RH-73868)
Rhino 8 WIP (8.0.23129) is now available for Windows and Mac
Bugs Fixed:
  • Override in render plug-in to select initial display channel in the render window (RH-74577)
  • CPlane: AutoAlign: AutoAlignCPlane should be a transparent command (RH-74631)
  • NamedView: Named View panel - no restore button (RH-71192)
  • RelocateGumball: Relocating the Gumball with Ctrl/Cmd has been broken (RH-74452)
  • UDT: CageEdit set all values to a single entered value (RH-72827)
Enhancements:
  • History: Add a toggle command or option for Recording History (RH-56397)
Mac-Only Changes
Bugs Fixed:
Rhino 8 WIP (8.0.23136) is now available for Windows and Mac
Bugs Fixed:
  • Grasshopper: Query components - inputs issues (RH-74799)
  • Display: Creating meshes again and again (RH-74422)
  • DocumentProperties: Edit Annotation Styles under the Drafting menu not working (RH-74729)
  • FilletSrf: FilletSrf Enter does not respond after changing something in the dialog (RH-73758)
  • PushPull: scripted version: ignore mouse direction (RH-74766)
Regressions Fixed:
  • LibrariesTab: New FileExplorer command (RH-74039)
SDK Enhancement:
  • SDK: RhinoCommon: Move SourceArchive to InstanceDefinitionGeometry (RH-74754)
Mac-Only Changes
Bugs Fixed:
  • Gumball: Gumball tooltips get focus and prevent Gumball from working correctly. (RH-74741)
Crashes Fixed:
  • Export: ll: Crash when switching to "Multiple Layouts" (RH-72274)
Rhino 8 WIP (8.0.23143) is now available for Windows and Mac
Bugs Fixed:
  • Annotation: Hatch: Solid hatch becomes gradient (RH-73576)
  • BooleanDifference: confusing wording (RH-74895)
  • CPlane: AutoAlign: Adhere to the setting of Rhino Options -> Modeling Aids -> Construction planes (RH-72336)
  • Curvature: graph: add support for SubD (RH-58162)
  • Display: Objects in block with SubD object become transparent (RH-74492)
  • FilletSrf:
    • Dialog is too persistent (RH-74809)
    • Did a poor job at some points of tangency (RH-68962)
    • Extend example (RH-72534)
    • FilletSrf fails to produce a complete fillet (RH-74777)
    • FilletSrf inaccurate results (RH-72556)
    • Did not expand across the whole edge (RH-72761)
  • Gumball: Gumball- extrude radially is missing (RH-74723)
  • MatchProperties: MatchProperties > Custom Mesh Setting breaks history (RH-74866)
  • OSnap: jumping UI item in Osnap / Filter panel (RH-74874)
  • RotateView: Rhino.Options.View.RotateViewAroundObjectAtMouseCursor doesn't stick right away (RH-74898)
  • SubD: Sharp edges: Sharp weight values could be asymmetrical on reflected SubD (RH-74117)
  • UI Appearance: SelectionFilter scaling issue (RH-73328)
Crashes Fixed:
  • Toolbar: Crash: Curve Tools toolbar causes Crash (RH-74834)
Enhancements:
  • Gumball: Added "Extrude closed" option to Gumball menu on status bar (RH-70904)
Mac-Only Changes
Crashes Fixed:
  • RDKCrash: Crash: Crash after Editing material (RH-74833)
Rhino 8 WIP (8.0.23150) is now available for Windows and Mac
Bugs Fixed:
  • BlockManager: Origin misalignment in preview (RH-72814)
  • Display Metal: Render mesh offset from wireframe with Metal (RH-74193)
Enhancements:
  • SelBlockInstanceNamed: Add Preselect Option to -SelBlockInstanceNamed (RH-75005)
SDK Enhancement:
Mac-Only Changes
Bugs Fixed:
  • Display Metal:
    • Grasshopper preview (RH-71648)
    • Does not work with draft angle analysis (RH-73903)
    • Metal: Shading of surfaces using display conduits fails if document empty (RH-74326)
Crashes Fixed:
  • Block: Crash when creating a block item (RH-74941)
Bugs Fixed:
  • Display: Box red in V7 and black in V8 (RH-74862)
