Thanks Dale, that explains it. Good to know the display and the checkbox are right and it is only the API reading backwards.
On the second thing I mentioned here, the cuts that stay hollow while others fill: I kept it out of this thread and have now opened a separate one, since it has nothing to do with this flag.
Short version, it is not the tolerance case from RH-84176, and it is not the fill rule. Two closed solids from your sectioning workflows class file never get a section fill, while a plain box on the same layer with the same style fills in the same frame. The attached file has all three objects in it
