In Rhino 8, The Toolbar Layout item is missing from the Tools menu. In Options | Toolbars the Save As item does not appear. Do I have an incorrect setting somewhere?
Regards, Garry.
Regards, Garry.
Hi Garry -
I’m not completely sure I understand what you are looking for.
If you want to save a custom UI layout, that can be found under the Window menu:
@wim That is it. Thank you.
Regards, Garry.
Thankyou so much it work ![]()
